Absturz: UPS Airbus A300-600 nähe Birmingham Alabama
Hat gedankt: 1250 mal
Danke bekommen: 375 mal
Beitrag von Swen » Mi 14. Aug 2013, 13:31
Ich habe es über Facebook erfahren. Erste Infos gibt es bei AVHerald seit kurzem:
http://avherald.com/h?article=466d969f&opt=0
Wetter Metar:
2013-08-14 06:06 METAR KBHM 141106Z 00000KT 9SM FEW005 OVC070 23/22 A2999 RMK AO2 FEW005 FU =
2013-08-14 05:53 METAR KBHM 141053Z 01003KT 10SM OVC070 23/22 A2999 RMK AO2 SLP146 T02330222 =
2013-08-14 04:53 METAR KBHM 140953Z 34004KT 10SM FEW011 BKN035 OVC075 23/22 A2997 RMK AO2 SLP141
T02330222 =
2013-08-14 04:04 METAR KBHM 140904Z 00000KT 10SM SCT010 BKN075 23/22 A2996 RMK AO2 =
2013-08-14 03:53 METAR KBHM 140853Z 00000KT 10SM BKN010 OVC075 23/22 A2997 RMK AO2 CIG 006V013
SLP138 T02330217 52000 =
Twitter:
https://twitter.com/myfoxal/status/367598464957308928
Flightradar24:
http://www.flightradar24.com/2013-08-14 ... 2x/UPS1354
Bei Flightradar kann man sehen, wie der Flieger vom Himmel gefallen ist.
UPDATE:
https://twitter.com/K_A_Turner/status/3 ... 32/photo/1
http://usnews.nbcnews.com/_news/2013/08 ... rport?lite
Re: Absturz: UPS Airbus A300-600 nähe Birmingham Alabama
Beitrag von Swen » Fr 16. Aug 2013, 13:11
In their second press conference on Aug 15th the NTSB reported the black boxes were recovered at about 11:00L after 3 hours of work, the boxes were blackened and sooted, the NTSB however is optimistic to retrieve good data from the boxes. The boxes are being shipped to Washington for analysis where they should arrive in the evening. It should be known on Friday (Aug 16th) whether there are good data on the boxes. Preliminary information shows no evidence of an engine's uncontained failure or fire prior to impact, there is also no evidence of a pre-impact ingestion of foreign objects. The radar data have been obtained. There are no indications of failure of runway/approach lighting, subject to verification. Runway 06/24 was closed at the time of the accident for maintenance of runway center line lights.
Quelle: AVHerald.com s.O.
Beitrag von Swen » Sa 17. Aug 2013, 21:10
In their third press briefing on Aug 16th 2013 the NTSB said, the "recorders did their job", there are good data, the cockpit voice recorder as well as the flight data recorder hold the entire flight. The captain (ATPL, 8,600 hours total, 3,200 hours on type) was pilot flying, the first officer (ATPL, 6,500 hours total, 400 hours on type) was pilot monitoring, the crew briefed the LOC approach runway 18, 2 minutes prior to the end of recording the aircraft received landing clearance on runway 18, 16 seconds before end of recordings there are two audible alerts by the GPWS "Sink Rate! Sink Rate!", 13 seconds prior to end of recording one crew member said "runway in sight", 9 seconds prior to end of recording sounds consistent with impact occurred. The flight data recorder contains more than 400 parameters requiring verification that these parameters are valid, this process takes time. It holds 70 hours of data including the entire accident flight. There were two controllers on duty at Birmingham tower, one controller was taking a break as permitted. The remaining controller observed the crash, he saw sparks and a large bright orange flash that he interpreted as breaking of a power line, he saw the landing lights, then no longer saw the landing lights and instead saw a large orange glow, he activated the crash button. There were no alerts regarding minimum safe altitude issued by his radar system. The crew started their "duty day" in Rockford,IL at 9:30pm on Aug 13th and flew to Peoria,IL as flight 5X-617 on A306 N161UP, then to Louisville,KY again as flight 5X-617 on N161UP before departing for the accident flight 5X-1354 on N155UP.
Beitrag von Swen » So 18. Aug 2013, 14:28
In their fourth and last press conference on Aug 17th the NTSB reported, the flight data recorder data have been validated. First results suggests the flight control inputs and flight control surface movements correlate, the engine parameters were normal. The flight data recorder stopped a few seconds prior to the cockpit voice recorder. The autopilot was engaged until the end of flight data recording end, the speed was about 140 KIAS as selected by the autoflight system consistent with the expected approach speed. The flight data recorder also confirmed the Sinkrate GPWS alerts. A checkflight by FAA on the PAPI system confirmed the PAPIs were indicating correctly to 1/100th of a degree. The aircraft had been updated to comply with all service bulletins and airworthiness directives.
Langsam wird es spannend...
