Heathrow - 787 Dreamliner hat gebrannt
Themen und Fotos von Airports rund um die Welt
Beitrag von Swen » Fr 12. Jul 2013, 19:03
Upsala... Gar nicht gut...
http://www.bbc.co.uk/news/uk-23294760
Re: Heathrow - 787 Dreamliner hat gebrannt
Beitrag von Swen » Fr 12. Jul 2013, 21:49
Beitrag von Swen » Fr 12. Jul 2013, 21:57
Beitrag von BSer » Sa 13. Jul 2013, 16:33
Bin sehr gespannt was es war. Bzgl. der anderen verlinkten Vorfälle: die ANA am 16. Januar war ja die Ursache für das lange Grounding, die Thomson gestern hatte Toiletten-Probleme, das kommt vor. Viel interessanter ist jedoch, ob die ET 788 repariert werden kann.
Beitrag von Swen » Sa 13. Jul 2013, 16:36
Die ANA hat mir AVHerald untergejubelt. Die haben an dem Tag ein Update rein geschoben und dann standen da drei Maschinen... Sorry... :(
Beitrag von Swen » Do 18. Jul 2013, 23:27
Beitrag von Swen » So 21. Jul 2013, 13:09
Neue Info:
On Jul 18th 2013 the AAIB reported in their special bulletin with respect to ET-AOP, that fire fighters encountered a fire above the ceiling panels close to the rear of the cabin, a halon extinguisher was not effective, only after a panel was moved and the fire was doused with water and foam the fire was extinguished. The origin of the fire coincided with the emergency locator transmitter (ELT), with no other systems in the vicinity storing sufficient energy to initiate a fire. The ELT is powered by a set of Lithium Manganese Dioxide Batteries, which showed disruptions of cells. It is unclear however whether the combustion started as result of energy release within the battery cells or by an outside event like a short circuit. Some 6000 units of this transmitter have been produced, ET-AOP is the only such incident so far. The AAIB recommended to the FAA to "inert" (deactivate) the ELTs in Boeing 787s until appropriate airworthiness actions can be taken and to conduct a safety review of all Lithium battery powered ELTs on all aircraft types.
http://www.avherald.com/h?article=45c377c5&opt=0
